EV6513GJ-00A
正在供货
0.8A, 21V Full H-Bridge Motor Driver Evaluation Board
    ¥ 342.50 /unit
Arrives 3-4 business days.
Shipping only $5 per order.
了解更多我们的评估板套件
咨询工程师或询价
产品描述
The EV6513-J-00A is an evaluation board for the MP6513GJ, Is a full-H-bridge motor driver used for driving reversible motors, which can drive one dc motor or one winding of a stepper motor or other loads.
It operates from a supply voltage range of 2.5V to 21V and can deliver motor current up to 0.8A.
The input control signals for the MP6513GJ are applied through the connector.
产品特性
  • Wide 2.5V to 21V Input Voltage Range
  • 0.8A continuous driver current
  • Full-H-bridge motor drive
  • OCP, OVP, and OTP
技术参数
2.5V - 21V, 0.8A, H-Bridge Motor Driver in a TSOT23-6
The MP6513 is an H-bridge motor driver used for driving reversible motors, which can drive one DC motor, one winding of a stepper motor, or other loads. The H-bridge consists of four N-channel power MOSFETs. An internal charge pump generates the necessary gate-drive voltages. The MP6513 operates on a motor power supply voltage from 2.5V to 21V, which can supply an output current of up to 0.8A according to the logic control. The MP6513 is controlled by two input pins. The two on/off inputs determine the output mode: forward, reverse, coast, or brake. Very low standby circuit current can be achieved when inputs 1 and 2 are both at a low level. Full protection features include over-current protection (OCP), short-circuit protection (SCP), under-voltage lockout (UVLO), and over-temperature protection (OTP). The MP6513 requires a minimum number of readily available, standard, external components and is available in a TSOT23-6 package.
2.5V - 5.5V, 0.6A, H-Bridge Motor Driver in a TSOT23-6
The MP6513L is an H-bridge motor driver used for driving reversible motors, which can drive one DC motor, one winding of a stepper motor, or other loads. The H-bridge consists of four N-channel power MOSFETs. An internal charge pump generates the necessary gate-drive voltages. The MP6513L operates on a motor power supply voltage from 2.5V to 5.5V, which can supply an output current of up to 0.6A according to the logic control. The MP6513L is controlled by two input pins. The two on/off inputs determine the output mode: forward, reverse, coast, or brake. Brake is applied when stopping the motor (when inputs 1 and 2 are both at a high level). Very low standby circuit current can be achieved when inputs 1 and 2 are both at a low level. Full protection features include over-current protection (OCP), short-circuit protection (SCP), under-voltage lockout (UVLO), and over-temperature protection (OTP). The MP6513L requires a minimum number of readily available, standard, external components and is available in a TSOT23-6 package.
