- MPQ20031-AEC1
MPQ20031-AEC1
The MPQ20031-AEC1 is an ultra-low dropout linear regulator that supplies up to 1A of current with a 1.6V to 5.5V input range. The device includes a low-dropout voltage, low quiescent supply current (IQ), and provides fast line and load transient performance, making it ideal for automotive battery-powered equipment.
The MPQ20031-AEC1 provides fixed output voltage (VOUT) options: 0.75V, 0.8V, 0.85V, 1V, 1.2V, 1.8V, 2.5V, 2.8V, or 3.3V. The device also provides adjustable-output options from 0.5V to 5V.
The MPQ20031-AEC1 is stable with small ceramic output capacitors, allowing for a small overall solution size.
Full protection features include integrated thermal shutdown, current limit foldback, power good (PG), and under-voltage lockout (UVLO).
The MPQ20031-AEC1 family provides different package options, including QFN-8 (3mmx3mm), QFN-8 (2mmx2mm), and TQFN-6 (2mmx2mm) packages. It is available in AEC-Q100 Grade 1.
- Built to Handle Tough Automotive Transients and Meet AEC-Q100 Requirements:
- Guaranteed Industrial and Automotive Temperature
- 0.5V to 5V Adjustable Output
- Fixed Output (0.75V, 0.8V, 0.85V, 1V, 1.2V, 1.8V, 2.5V, 2.8V, or 3.3V)
- Outputs ±1.4% Over-Temperature Accuracy
- Stable with Low Output Ceramic Capacitance (>1μF)
- Extends Vehicle Battery Life:
- 26µA Quiescent Supply Current (IQ)
- Supports Multiple Package Options:
- Small QFN-8 (3mmx3mm) Package
- Small QFN-8 (2mmx2mm) Package
- Small TQFN-6 (2mmx2mm) Package
- Additional Features:
- 1A Nominal Current
- Current Limit Foldback
- Power Good (PG)
- Functional Safety System Design Capable:
- MPSafeTM Compatible-Functional Safety Supporting Document Available
MPQ20031GQE-xxx0-AEC1-Z MPQ20031GQE-xxx0-AEC1-P MPQ20031GQE-xxx1-AEC1-Z MPQ20031GQE-xxx1-AEC1-P MPQ20031GGTE-xxx0-AEC1-Z MPQ20031GGTE-xxx0-AEC1-P MPQ20031GGE-xxx0-AEC1-Z MPQ20031GGE-xxx0-AEC1-P
MPQ20031-AEC1 Resources
LDO产品类目 -
MPQ20082-AEC1产品40V、300mA、低静态电流、可调输出、线性稳压器,符合 AEC-Q100 认证
MPQ2013D-AEC1产品40V、100mA、低静态电流线性稳压器,符合 AEC-Q100 认证
MPQ2026A-AEC1产品300mA、40V、双幻象天线 LDO, 具有预升压 (Pre-Boos) 功能、行业标准同步串行接口和用于数字诊断的 ADC,符合 AEC-Q100 认证
MPQ2022A-AEC1产品40V、300mA 双通道 LDO,具有串行数字接口和用于数字诊断与保护的ADC,符合 AEC-Q100 认证
MPQ2024A-AEC1产品40V、300mA 、幻象天线LDO,具有预升压、数字接口和用于数字诊断与保护的 ADC,符合 AEC-Q100 认证
MPQ2016-AEC1产品40V、30mA、低静态电流(IQ)线性调节器,符合 AEC-Q100 认证
MPQ20073-AEC1产品2A、1.3V–6.0V DDR 存储器终端调节器,符合 AEC-Q100 认证
MPQ2019-AEC1产品40V、300mA、低静态电流可调输出线性调节器
MPQ2013-AEC1产品40V, 150mA, 低静态电流线性调节器
MPQ2029-AEC1产品汽车级 40V、450mA、低静态电流可调输出线性调节器,符合 AEC-Q100 认证
MPQ20051-AEC1产品低噪音,高PSRR, 1A 线性调节器,符合AEC-Q100 认证
MPQ20056-AEC1产品低噪声、高PSRR的250mA 线性调节器,符合AEC-Q100 认证
MPQ8904-AEC1产品汽车级 500mA 线性调节器
MPQ2013A-AEC1产品40V、150mA、低静态电流线性调节器,搭载 EN 引脚
REFERENCE DESIGN
适用于XILINX ZU+ 的可扩展汽车电源参考设计本参考设计为采用AMD Xilinx Zynq Ultrascale+系列SoC(从ZU2CG到ZU5EG)的汽车应用提供电源,它采用多个小型DC/DC变换器,可灵活配置为PoL(负载点)电源 。 MPQ8886具备双3A输出和多IC操作功能,其扩展性可以满足每个ZU+器件的特定需求,同时实现最经济的解决方案。MPQ8886的输出可与单个电感器并联以降低成本,或用于180º相位交错以改善瞬态响应,并减少通过汽车EMC认证所需的输入电容和滤波。具体所需的MPQ8886 IC数量则取决于VCCINT电源轨上的ZU+器件电源需求。 此外,MPQ8886的数字接口可随时调节输出电压以优化功耗,而且当功耗较低时,可以关闭单个相位的电源。 ...
REFERENCE DESIGN
ZYNQ ULTRASCALE+ MPSOC U2EG/U3EG ADAS 摄像头传感器和处理系统电源参考设计参考设计 -
REFERENCE DESIGN
ZYNQ ULTRASCALE+ U4EG/U5EG/U7EG ADAS 中央处理器电源解决方案参考设计参考设计
