- MPQ8874-AEC1
MPQ8874-AEC1
36V, 4A, Four-Switch, Synchronous Buck-Boost Converter with I2C Interface, AEC-Q100 Qualified
The MPQ8874-AEC1 is a 36V, monolithic, synchronous buck-boost DC/DC converter. The wide 2.2V to 36V input voltage (VIN) range makes this device well-suited for multi-purpose automotive and industrial applications. The proprietary constant-on-time (COT) control, as well as the fully integrated, four-switch configuration, allow the chip to flexibly change the converter topology between buck, boost, and buck-boost mode. This optimizes performance and efficiency with input voltages that are above, below, or equal to the output voltage (VOUT). It also ensures seamless transitions between the adjacent operational regions.
The MPQ8874-AEC1 is controlled separately via a standard I2C interface. The various parameters can be adjusted by writing the settings to the device without any hardware changes required.
The switching frequency (fSW) can be configured between 200kHz and 2.2MHz, or it can be synchronized between 250kHz and 2.2MHz via an external clock signal. In addition, the configurable frequency spread spectrum (FSS) function can dither fSW periodically for improved EMI performance.
Robust fault protections include input under-voltage lockout (UVLO), input over-voltage protection (OVP), cycle-by-cycle peak current limiting, output OVP, output short-circuit protection (SCP), and thermal shutdown. The built-in power good function (PG) can indicate whether the VOUT is regulated properly.
The MPQ8874-AEC1 is available in a thermally enhanced QFN-22 (4mmx5mm) package. It is available in AEC-Q100 Grade 1.
- Designed to Handle Automotive Transients:
- 4V to 36V Wide Input Voltage (VIN) Range
- Load Dump Up to 42V
- Cold Crank Down to 2.2V
- Single-Channel, Four-Switch, Synchronous Buck-Boost Configuration:
- Internal Buck High-Side Power MOSFET (HS-FET)
- Internal Buck Low-Side Synchronous Rectifier (SR)
- Internal Boost Low-Side Power MOSFET (LS-FET)
- Internal Boost High-Side SR
- Proprietary Constant-On-Time (COT) Control for Seamless Transitions
- Up to 4A of Continuous Output Current (IOUT) in Buck
- Extends Vehicle Battery Life:
- 1μA Shutdown Current
- 20μA Quiescent Current (IQ)
- Easy-to-Optimize Efficiency and EMI Performance:
- Configurable 200kHz to 2.2MHz Switching Frequency (fSW)
- Synchronizable fSW from 250kHz to 2.2MHz
- Switching Frequency Spread Spectrum (FSS)
- Configurable Switching Speed
- Reduced Board Size and BOM:
- Integrated Compensation Network
- Fixed Output Voltage (VOUT) Options
- Rich Protections and Diagnostics:
- Configurable Input Under-Voltage Lockout (UVLO)
- Cycle-by-Cycle Current Limiting
- Over-Current Protection (OCP)
- Output Over-Voltage Protection (OVP)
- Input OVP
- Output Under-Voltage Protection (UVP)
- Over-Temperature Shutdown
- Power Good (PG) Indication
- Application Flexibility with I2C Interface:
- 1Mbps I2C Interface with Packet Error Checking (PEC)
- Configurable Parameters:
- Converter On/Off
- Input Range Selection
- Output Range from 1V to 30V
- fSW
- Synchronized Input/Output Selection
- Switching Slew Rate
- FSS Setting
- Compensation Network
- Soft-Start Time (tSS)
- Dynamic VOUT Adjustment with Slew Rate Control
- Converter Mode Transition Threshold
- Discontinuous Conduction Mode (DCM) or Forced Continuous Conduction Mode (FCCM)
- Protection Thresholds
- Fault Behaviors
- PG Threshold
- Additional Features:
- One-Time Programmable (OTP) Memory for Default Parameter Setting
- Available in a QFN-22 (4mmx5mm) Package
- Available with Wettable Flanks
MPQ8874GVE-xxxx-AEC1-Z MPQ8874GVE-xxxx-AEC1-P
MPQ8874-AEC1 Resources
降压/升压(升降压BUCK-BOOST)变换器和控制器产品类目 -
MPQ4208-AEC1产品80V, Synchronous Buck-Boost Controller with I2C And Adjustable OCP and PG Indication, AEC-Q100 Qualified
MPQ8835A-AEC1产品36V, 6A, Four-Switch, Synchronous Buck-Boost Converter with I2C Interface, AEC-Q100 Qualified
MPQ4214-AEC1产品40V 同步升降压控制器,带数字接口并可通过 IPWM 调节 OCP,符合 AEC-Q100 认证
MPQ8873-AEC1产品36V、3A 连续输出电流、全温、4 开关、同步升降压变换器、符合 AEC-Q100 认证
MPQ4210产品40V、100W 同步升降压控制器,具有I2C接口和电流监控功能,符合 AEC-Q100 认证
MPQ4233A-AEC1产品36V、3A、升降压变换器,带四个集成 MOSFET 和 I²C接口并符合 AEC-Q100 认证
MPQ4232A-AEC1产品带4个集成 MOSFET 和 I²C 接口的36V、6A 升降压变换器,符合 AEC-Q100 认证
MPQ4233-AEC1产品具有36V 耐受电压并带4个集成 MOSFET 和 I2C接口的3A升降压变换器,符合 AEC-Q100 认证
维持汽车启动条件的设计考量技术文章使用 12V 电池系统的现代汽车会受很多瞬态条件的影响。其中部分瞬态涉及高压脉冲,而另一些则涉及低压条件。启动瞬态是汽车引擎发动时产生的低压状况,期间,汽车电池电压会在短时间内下降至低于正常工作范围好几伏。 保持车辆在各种启动条件下也正常运行的要求在近几年中越来越严格,随之而来的,是对更强大的电源解决方案的迫切需求。根据启动波形来设计,再加上负载必须由特定电源轨供电,要设计满足这些要求的系统,设计人员压力不小。本文将介绍一款功能强大的 DC/DC变换器,它可以承受各种汽车启动瞬态。 设计 12V 汽车系统必须考虑极端启动条件(见图 1)。ISO 16750-2、ISO 7637-2 和Test Pulse 4 等标准定义了许多车辆启动曲线,包括冷启动条件、热启动条件以及类似波形相关的启动曲线。 图 2 显示了冷启动波形的示例,其启动曲线由 ISO 标准定义。 ...
