- MPQ2211-AEC1
MPQ2211-AEC1
6V, 12A, 2.2MHz, Configurable Current Limit, Synchronous Step-Down Converter, AEC-Q100 Qualified
The MPQ2211-AEC1 is a fully integrated, high-frequency, synchronous buck converter. It offers a very compact solution to achieve up to 12A of output current (IOUT) across a wide input supply range, with excellent load and line regulation. The device operates at high efficiency across a wide IOUT load range.
The MPQ2211-AEC1 adopts an internally compensated constant-on-time (COT) control mode that provides fast transient response and eases loop stabilization. Pulse-skip mode (PSM) enables asynchronous operation to optimize light-load efficiency. The device also provides a fixed 2.2MHz frequency, allowing its frequency to remain constant regardless of the input voltage (VIN) and output voltage (VOUT).
The VOUT start-up ramp is controlled by an internal 0.9ms timer, and can be increased by adding a capacitor on the SSTT pin. An open-drain power good (PG) signal indicates the output is within its nominal voltage range. The PG pin is clamped to about 0.7V with an external pull-up voltage if the input supply fails to power the MPQ2211-AEC1.
Fully integrated protection features include over-current protection (OCP), over-voltage protection (OVP), under-voltage protection (UVP), and over-temperature protection (OTP).
The MPQ2211-AEC1 requires a minimal number of readily available, standard external components, and is available in an LGA-19 (3mmx3.5mm) package.
- Designed for Automotive Point-of-Load (PoL) Applications:
- Wide Operating Input Voltage (VIN) Range from 3V:
- 3V to 3.6V Range with VCC Bias to VIN
- 4V to 6V Range with Internal Bias
- Up to 12A of Continuous Output Current (IOUT)
- Configurable, Accurate Current Limit
- Constant-On-Time (COT) Control Provides Excellent Transient Response
- Increases Battery Life:
- Pulse-Skip Mode (PSM) at Light Loads
- Internal Power MOSFET Switches
- Optimized for EMC/EMI:
- 2.2MHz Switching Frequency (fSW) in Forced Continuous Conduction Mode (FCCM)
- MeshConnectTM Flip-Chip Package
- Additional Features:
- Power Good (PG) Actively Clamped Low during Power Failures
- Output Voltage (VOUT) Discharge
- VOUT Tracking
- ±1% 0.5V Feedback (FB) Accuracy
- Configurable Soft-Start Time (tSS) from 0.9ms
- Adjustable Output Up to 3.6V
- Non-Latched Over-Current Protection (OCP), Under-Voltage Protection (UVP), Under-Voltage Lockout (UVLO), Thermal Shutdown
- Latch-Off Over-Voltage Protection (OVP)
- Available in an LGA-19 (3mmx3.5mm) Package
- Functional Safety System Design Capability:
- MPSafeTM Compatible – Functional Safety Supporting Document Available
MPQ2211GLC-AEC1-Z MPQ2211GLC-AEC1-P
MPQ2211-AEC1 Resources
开关变换器和控制器产品类目 -
MPQ29261-AEC1产品18A, Synchronous Step-Down Converter with 2-Bit VID, AEC-Q100 Qualified
MPQ2283-AEC1产品6V、6A、可配置、高频、同步降压变换器,采用ZDPTM,符合 AEC-Q100 认证
MPQ2283GLE-XXXX-AEC1-Z产品6V、6A、可配置高频同步降压变换器,符合 AEC-Q100 认证
MPQ8880A-AEC1产品60V、4.5A、高效率、数字、可配置、同步降压变换器,带PMBus接口且符合 AEC- Q100认证
MPQ2287-AEC1产品采用ZDPTM 的6V、14A、可配置高频同步降压变换器,符合 AEC-Q100 认证
MPQ2288-AEC1产品6V、16A、可配置、高频、同步降压变换器,采用 ZDPTM并符合 AEC-Q100 认证
MPQ4374-AEC1产品40V、12A 至 16A、大电流输出、同步降压变换器,采用ZDPTM且符合 AEC-Q100 认证
MPQ3524-AEC1产品20V、0.5A 至 4A 峰值、低静态电流 IQ、超紧凑型同步降压变换器,符合 AEC-Q100 认证
